A break through in the treatment of osteoarthritis and rheumatoid arthritis. The JStim is developed with the indication of use for Osteoarthritis or Rheumatoid Arthritis. Due to the unique combination of advanced electrotherapy stimulation and compression the JStim is likely to provide pain relief and overall improvement to one's arthritic condition. The Jstim is an advanced electrotherapy device that works in tandem with soft multi-layer conductive fabric and compression therapy wraps allowing the silver garment electrodes to emit therapy directly into the target joint. These combined modalities are compressed against the treatment site using compression wraps allowing the silver garment electrodes to emit therapy directly into the target joint. It is safe effective and convenient to use your Jstim at night while sleeping. The Jstim is a cumulative therapy and should be part of a therapy regimen for 6-12 months for optimal results. The JStim 1000 Knee System utilizes a high-quality knee compression wrap and specific conductive silver fabric electrode patches that connect to the JStim stimulation unit.
Features
